Go to Post I love FIRST... - jess523s [more]
Unread 04-02-2010, 10:29
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Question Robot Starting Positions
Originally Posted by Competition Manual Section 7 - The Game (Revision F)
<G08> ROBOT Starting Positions – Prior to the MATCH, each TEAM negotiates within their ALLIANCE to select one of the three starting areas for their ALLIANCE.
When the FIELD is viewed from the ALLIANCE STATION, the ROBOTS must be placed on the right side of the CENTER LINE in one of the following starting positions:
• In the far ZONE and in contact with the ALLIANCE STATION WALL and/or ramp.
• In the MIDFIELD and in contact with the farthest BUMP.
• In the near ZONE and in contact with the nearest BUMP.
As I interpret this, the robot that starts in the far zone could be touching only the ramp in front of the opposing alliance's goal (and NOT touching the alliance station wall) which will put you much closer to the ball starting grids than the robots in the other two zones.
It seems to me that the intent of these starting positions should restrict the robot in the far zone to only touching the alliance station wall regardless of if it is touching the ramp or not. If that is the case, my version of that first bullet would read "In the far ZONE and in contact with the ALLIANCE STATION WALL." What are other people's thought on this?
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 04-02-2010, 10:41
MrForbes MrForbes is offline
Re: Robot Starting Positions
52 feet from the goal isn't enough of a challenge? it's gotta be 54 feet?
Unread 04-02-2010, 11:34
GaryVoshol's Avatar
Cogito ergo arbitro
Allowing wall or ramp allows the robot the full width of the half of the field, as is allowed in the midfield and near zones.
(since 2004)
Unread 04-02-2010, 11:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Making the ramp off limits as a starting location would make a simple "drive forward and kick" autonomous strategy harder to implement.
Unread 04-02-2010, 11:44
SuperJake's Avatar
No Problem!
AKA: Jake Classic
I wasn't attempting to imply that the ramp would be off limits - only that you had to touch the wall. That is to say that if you were in the far zone, your valid starting positions would be:
  • In contact with Alliance Station Wall and NOT on the ramp
  • In contact with the Alliance Station Wall and on the ramp
Where the rule as currently stated adds another case of:
  • NOT in contact with the Alliance Station Wall and in contact with the ramp
This allows your robot to start very close to the first ball in your zone - closer than any of the robots in your alliance's other zones.
Unread 04-02-2010, 11:50
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
A small robot on the ramp may not be able to physically touch the alliance wall since the goal is there.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
It's a game feature, they're helping us, please don't complain too loudly....
Unread 04-02-2010, 11:51
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
And in exchange for that you're really far from the goal. Sounds about right to me.
Unread 04-02-2010, 12:14
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
The rule regarding starting positions is what it is. It is not going to change. Leave it alone.
Unread 04-02-2010, 12:18
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Touchy?
Seriously though, Dave is right. The rule is what it is, plan for teams to use it (and maybe use it yourself?).
___________________
- Tennyson, Ulysses
Unread 04-02-2010, 12:52
SuperJake's Avatar
No Problem!
AKA: Jake Classic
I think I am starting to see light at the bottom of the hole I am digging...
I will absolutely be utilizing the ramp starting position in my strategy repertoire... it just stood out in my mind as one thing that didn't look like the others and struck me as odd... I was wondering what other people thought.
See you at the competition!
Robot Positions Sammy G Rules/Strategy 2 11-01-2010 22:25
starting positions and penalties jamie_1930 General Forum 8 29-03-2009 14:48
Starting Positions ... 'bots vs. Humans Ziaholic Rules/Strategy 7 08-01-2009 11:30
starting/ending robot configuration Japper General Forum 4 10-02-2008 16:28
Robot Starting Position Alignment Makubesu Rules/Strategy 2 09-02-2006 19:16
