Go to Post PS: When/if it gets to be too easy to build a machine that can accomplish a recent/typical FRC game, then I suspect it will be time for someone to unveil a harder game. - gblake [more]
Unread 02-02-2010, 22:50
Imadapocalypse's Avatar
Imadapocalypse Imadapocalypse is offline
The Walking Contradiction
AKA: Bryce Ribucan
FRC #2443 (Blue Thunder)
Imadapocalypse is an unknown quantity at this point
Send a message via AIM to Imadapocalypse
pic: Bumper Velcro 1
Unread 02-02-2010, 22:56
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: pic: Bumper Velcro 1
I like the idea of Velcro, but I will warn you now. This game is going to have a LOT of contact, and if those bumpers fall off you will receive penalties. Even if the Velcro is extremely strong, stuff does happen.
Now, I don't know how strong that Velcro is, so I very well might be wrong. It all depends on the strength of it. But i would still recommend another way, along with the Velcro, to attach your bumpers.
I hope this helped, and good luck this year! To you and all teams!
Unread 03-02-2010, 00:29
EricH EricH is online now
I hope that that is for your bumper covers. If it is for your bumpers to attach to the robot, you need to read <R07-I> right away.
I. BUMPERS must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro). The attachment system must be designed to withstand vigorous game play – nut and bolt fasteners are recommended. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
Like I said, if that's for bumper covers, you're probably OK. If it's for the bumpers to attach to the robot, you're not going to pass inspection if the inspector knows the rules like they should.
Unread 03-02-2010, 01:59
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
heyyy its maui high !!
Unread 03-02-2010, 02:02
jsasaki's Avatar
AKA: Jun Sasaki
heyyy its maui high !!!
Unread 03-02-2010, 18:47
AKA: Bryce Ribucan
haha @jsasaki
i hope you guys arent thinking we're gonna use velcro to put the bumpers on the robot. We plan to use the velcro for the bumper covers. ideally making two sets would be the plan but we probably will not have enough room for two sets when we fly to regionals
The needs of the many out-weigh the needs of the few and the one
Unread 03-02-2010, 19:10
Cyberphil's Avatar
That Guy
AKA: Phil
I was worried there for a second. Thank you for clarifying that.
Unread 05-02-2010, 14:59
djdaugherty djdaugherty is offline
Mrs. D.
FRC #2053 (TigerTronics)
djdaugherty is on a distinguished road
In the picture, there is plywood showing on the back of the bumper. It seems like Update #7 says that all the plywood, even on the back, needs to be covered by the fabric. Is that the impression everyone is getting?
Thanks!
Unread 05-02-2010, 15:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks!
What part of Update 7 is leading you to believe that?
I don't see the words plywood, back, or backing in Team Update 7 or any language that seems to reference the plywood.
Unread 05-02-2010, 16:21
Update #7 was only talking about bumper covers and the risks associated with their coming off during a match.
<R07-E> specifies the cover requirements, namely that the covers cover all exposed pool noodles or plywood. Note that Figure 8-1 does not show the cover going all over the back. This leads to the interpretation that "exposed" refers to any part of the bumper that could hit another robot. Plenty of robots have passed in previous years with the plywood back showing under an identical wording of that rule.
Also note that it is not illegal to cover the entire back of the bumper with the cloth. However, it may make mounting more difficult.
Velcro? fhobart General Forum 7 17-02-2009 12:09
sandpaper and velcro mrnoble Technical Discussion 4 06-01-2009 23:10
gaint velcro Creator Mat Rules/Strategy 7 04-01-2009 23:22
Velcro to pick up trackball Ponderous Technical Discussion 20 14-01-2008 21:49
use of velcro in 04? SuperDave Rules/Strategy 2 31-01-2004 18:50
