Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 06-02-2010, 17:29
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
Re: pic: 12 wheels?
Originally Posted by Ken Leung View Post
Hi. Just curious, can you explain a little bit the advantage of pair two different types of wheels together?
Well, we originally had only the gray KOP wheels mounted, and we drove it around/over the bump with this setup and we needed about a 2 foot run-up to get over and turing on top of the bump was....difficult.
So we decided we needed more traction to help us climb, at the same time, adding the second wheels will make it easier to turn on top of the bump.
Third, we noticed if the robot falls to one side of the bump and slides back down sideways, the bottom of our frame hits the ground and we lose traction on the side that is furthest up the bump. Then, in the proccess of getting ourselves un-stuck, our frame rails could damage the carpet.
We also get more grip on the carpet while maintaning our quick turning ability.
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
pic: Variable Diameter Wheels? In Vex?! - pic 1 artdutra04 Extra Discussion 2 07-09-2006 20:53
pic: Variable Diameter Wheels? In Vex?! - pic 3 artdutra04 Extra Discussion 13 07-09-2006 17:37
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
