Go to Post If that due diligence shows that a real need for action exists, *then* grab the pitchforks, and light the torches. - gblake [more]
Unread 06-02-2010, 17:57
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
pic: Team 2502 Chassis Teaser
Techgirl675's Avatar
Techgirl675 Techgirl675 is offline
FRC #0675
Techgirl675 will become famous soon enough
Send a message via AIM to Techgirl675
Re: pic: Team 2502 Chassis Teaser
looks verrrry heavy...
"You're doin it wrong!"
http://techhighteam675.com/
Unread 06-02-2010, 18:05
firemaster193's Avatar
firemaster193 firemaster193 is offline
FRC #2130
firemaster193 is an unknown quantity at this point
it seem too heavy
Unread 06-02-2010, 18:11
keehun's Avatar
Team Captain
AKA: Keehun Nam
How heavy is heavy? With gearboxes, motors, electronics, the calculated weight is 50lb...
And I can lift this with one arm. Easier to lift with two arms..
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 06-02-2010, 18:27
FRC #0675
For sake of comparison our chassis with 4 CIMs, mechanum wheels and all 4 gear boxes is less than 35 pounds...
For what it's worth, we've gone the 80/20 route. While it's great for prototyping and testing, we've found it's far too heavy for competition use. We've since switched to welded thin-wall steel tubing and it seems to work quite well.
Unread 06-02-2010, 18:34
Timz3082 Timz3082 is offline
FRC #3082 (Chicken Bot Pie)
Timz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the roughTimz3082 is a jewel in the rough
Thumbs up Re: pic: Team 2502 Chassis Teaser
It does look a bit heavy, But it also looks very strong! Good work from team 3082 (Minnetonka)! I can't wait to see this at 10,000 Lakes! What drive train are you using? It looks like it could be a swerve...Well I gues I will see in two months
Unread 06-02-2010, 18:56
Nice chassis. One of the coolest uses of extrusion I've seen so far. Though that's not saying much. That's a lot of material, but it's material fairly low, which should be good for your CoG.
I'm intrigued with the wide orientation. Can't wait to see the rest of it, so I know why you guys took that route.
Unread 06-02-2010, 19:06
Originally Posted by firemaster193 View Post
it seem too heavy
It depends on what the rest of the robot needs in terms of weight. 70 pounds is more than plenty for what they plan on doing, as far as I've heard their plans.
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Trust us you'll be surprised how weight seems to adds up... fair warning just make sure you are careful how heavy the rest of your robots functions are.
Co-Founder of Taplytics.com
Unread 06-02-2010, 19:19
dragon72950 dragon72950 is offline
FRC #0675
dragon72950 will become famous soon enough
calculated weight do you know how heavy it actually is or have you not weighed it yet?
Unread 06-02-2010, 19:23
Most of the parts he named aren't on the robot yet, so it's hard to weigh the final configuration.
50lbs with all electronics is plenty light, I think. Personally aiming for a 70 pound lower deck / 110 pound robot.
Unread 06-02-2010, 19:26
FRC #0675
well he could do what we did and just put the stuff on the scale with the chassis
Unread 06-02-2010, 19:29
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
Looking good
Interested on the wide base configuration
Unread 06-02-2010, 19:38
EricH EricH is offline
Some folks might not have a scale that will work for that.
Unread 06-02-2010, 21:54
keehun's Avatar
Team Captain
AKA: Keehun Nam
I will weigh it this coming monday.
And we do have a very interesting wide-configuration that will be super weird but we hope to have work out!
And no swerve this year. We thought that whatever we could make would have too low of a clearance to go over the bump.
Hm, did I give too much away?
pic: Team 935 Chassis Teaser railerobotics Extra Discussion 24 08-02-2010 15:24
pic: Team 2502 Driver Station keehun Extra Discussion 2 12-04-2009 15:24
pic: Team 2502 Robot 2009 keehun Extra Discussion 4 18-02-2009 20:55
pic: Team 665 REAL Chassis, Kinda-Teaser Greg Peshek Extra Discussion 13 25-01-2008 08:14
pic: Team 1676 Chassis Teaser Spiffizzle Robot Showcase 10 28-01-2006 23:53
