Re: pic: 1747- Kicker Winch
Sweet idea! Are you having any problems with the gear teeth breaking under the increased forces as they engage/disengage? How fast does it pull back/whats your kickers range? Show this baby on the final bot too please
Can you share the gear ratio of the gearbox? Standard Toughbox or custom?
It is a modified toughbox, containing only a 14 tooth CIM gear (attached to the window motor) and a 50 tooth output gear. The cylinder disengages the gear, allowing a 6" IFI wheel attached to the output shaft (not shown) to spin freely.
We added more structure than what you seen in this picture to prevent the bottom plate from bending when the cylinder extends. We will probably increase the cylinder bore size to 2", since the current one cannot hold the load we desire. |
Holy bending angle bracket batman! You might want to consider cross-bracing on that bracket?
I like the idea though! What ensures that the gears re-mesh after a shot? |
The bearing holes are slotted in the toughbox casing. So far, by just using that slot to guide the gear and extending the cylinder, we have had no problem keeping the gears engaged. The only issue we have is when a large force is applied, the gear sometimes skips. Last edited by Ben Martin : 08-02-2010 at 10:46. |
We can load the kicker to its full strength in less than 5 seconds; hard numbers will come later. Our range is currently approximately 18' with a height of 2'. However, we are testing foot designs/angles to see what works best. Will do. Come to BMR, Buckeye, or Atlanta and see for yourself! ![]() |
Very interesting take on a clutch mechanism. I'd like to see some video of it in action if you have any.
-Brando |
For anybody having issues with kicker winches, these little window motors work great
Of course they don't back drive unless you really pull on them. |
The little window motors don't do much work, compared to a CIM, so you might need to wait around a while for it to winch up your cable
#10
Agreed, we used the CIMs and Fishers on ther things, so I had a choice of pneumatics, the 555 or the window. The 555 is pathetic. On our system the window motor is directly coupled to the shaft, and takes 3 seconds to winch back 70 pounds. Ball is going 40 feet at 9 feet at it's highest point. Of course we just go off half cocked to shoot closer to the goal.
| pic: Winch for Kicker | MrForbes | Extra Discussion | 10 | 10-02-2010 10:42 |
| pic: 1747 Teaser | 1747robotics | Extra Discussion | 3 | 07-02-2010 23:57 |
| pic: Buckeye: 1747 Panda Pose | Dan 1038 | Extra Discussion | 9 | 03-03-2009 17:23 |
| pic: 1747 Turret Close up | Allison | Robot Showcase | 2 | 20-02-2007 10:16 |
| pic: Vex Winch | AdamHeard | Extra Discussion | 5 | 16-11-2006 23:30 |
