Go to Post We were asked to help change a culture. If the solution was simple FIRST would have given more specific guidelines on how to do this. It is our job as teams to find unique and creative ways to help fulfill the request from FIRST. - tim-tim [more]
Unread 02-08-2010, 08:16 AM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: Telescoping Arm Warning
Originally Posted by JamesCH95 View Post
If your second telescoping stage was moving twice as fast as the first then it has a 2x mechanical advantage and sees only 1/2 the force of the first stage, not twice the force.
Calling the stages "first" and "second" implies a reference point. You're labeling things from the point of view of the driving motor, in which case I'm not sure the term "mechanical advantage" is being applied properly.
Aaron described it from the other perspective, with the slower-moving stage experiencing twice the force applied to the faster-moving stage. They were testing it by pulling down on the end, applying force to what you labeled the "second" stage.
Unread 02-08-2010, 08:34 AM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
You're right, I had it mixed up. Apologies! That's what I get for reading posts at 730am
The problem is that the rope's BREAKING load and WORKING load are different criterion. The breaking load can be approached once, whereas the working load can be reached safely many many times.
Unread 02-08-2010, 09:53 AM
Rion Atkinson's Avatar
The CAD Guy
Originally Posted by Vikesrock View Post
Note:
FRC 111 is Wildstang
FRC 1114 is Simbotics
You see... I verified that on TBA.... I knew the difference... I forgot to add the 4.... Sorry about that.
Either way. 111, 148, or 1114, I would still do it in a heartbeat.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 02-08-2010, 10:08 AM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by daltore View Post
...The 1000-pound breaking strength Spectra we were using in the pulley system did...
While Spectra is extremely strong for it's diameter, stronger than steel of the same diameter, it is also VERY slippery! If you intend to use it as your primary lifting line, make sure you understand all of it's properties and how to deal with them.
Here is a hint from the kiting community: Sleeve the ends of the line. Here is another source of info on sleeving, this has picture to help guide you.
Unread 02-10-2010, 09:16 PM
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
We're using 1/4" vectran rope from McMaster, which has a working load of 1500lbs. Make sure whatever rope or cable you're using has a WORKING LOAD in the range you want that that you're never exceeding any bending allowance.
The problem with UHMWPE is that it's used for so many different purposes and it's properties change so easily that they never rate it for working load, only breaking strength. The actually working properties are pretty interesting, the molecular bonds are fairly weak (Van der Waals forces hold it all together), but the molecules are very long, so the surface area between the molecules is enough to provide a lot of strength. That force changes pretty quickly when there's any kind of bend in the line, temperature difference, if it's wet, if it's a Saturday.... Vectran is quite a bit more stable, but lower strength per cross-sectional area, which is the reason we went with UHMWPE (not to mention price, it's a little older and proven material, and used more commonly in commercial applications like boating and rock climbing).
Thanks for all of the suggestions, this is very helpful!
Unread 02-10-2010, 09:44 PM
travis travis is offline
FRC #2091
travis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of light
Some people will tell you that there is no rope on a sailboat, but this only holds true for an ill-prepared one. Even fancy pants spinneret-ed high tech fiber used for holding stuff together on an america's cup boat is called rope when it is on the spool, as "rope" is the term for the raw material. A line is a usefully knotted/spliced/whatever amount of rope. So next time "captain" Bill castigates you with the old chestnut, tell him to wait while you go get some, cause how else are you getting home if the halyard snaps?
Unread 02-10-2010, 11:08 PM
_Tanto_'s Avatar
_Tanto_ _Tanto_ is offline
_Tanto_ is an unknown quantity at this point
hahah oooo nooooo D:
"a triscuit can only do what a triscuit does"
Unread 02-13-2010, 02:13 AM
daltore's Avatar
AKA: Aaron Osmer
Update: The 3840 lb. Dyneema works! To weight test the system, I stood on the arm and the motor lifted me right up, no problem! Did the same for the robot, and then Richard and I hung on it. The first time we hung, something dropped down, but the Dyneema was fine, it was just under enough tension that it forced a spacer on the axle (a Delrin shroud that extended the 1/2" steel axle to 1") away from the sprocket and popped down to the next level. We fixed that problem and got all 4 feet off the ground for several seconds. It was quite impressive! We're adding in a tensioning system for the one knot we had stationary because it undid a little bit and detensioned the rope, but overall, I'm very happy with this material!
I highly recommend this stuff, just a few suggestions if you use it in the future:
1) It's a little hard to work with, but as was said before, 2 half hitches or a taut-line hitch work well when tying it, and always use a much bigger rating than you think you will need. Example: 500 pound load, didn't hold until we went to almost a 2-ton line!
2) Spectra/Dyneema (brand names of Ultra High Molecular Weight Polyethylene, UHMWPE) is very slick, and does not like any kind of friction-based system. It will not work like a belt, it has to be tied down (the knots only work because there's so much pressure between the strands of material). To drive it off of our shaft, we actually had to drill a hole through the shaft, and then tie it down with a constrictor knot to keep it from moving in the hole.
3) If there is ANY kind of rubbing or abrasion, it will VASTLY weaken the rope. Just because the breaking strength is high doesn't mean it's hard to cut. The rating is just for a tension load, not shearing. We broke our first rope with 50 pounds of weight on it alone because we sheared it when it jumped a pulley.
Thanks for all the help, and good luck in competition!
Unread 02-16-2010, 03:18 PM
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
2)
Working load ratings are much different from breaking load ratings!! Can't stress that enough!
Also, one physical test is worth a thousand models and calculations.
Unread 02-16-2010, 08:57 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Is that a pun?
Anyway, we're going with 5/32" steel cable, as I insisted upon a 10:1 factor of safety for our single bot (we don't expect to be lifting anyone else), and 1/8" was just at the limit.
Simply put: If that cable breaks, we're toast. Lesson to be learned: Don't let that cable break.
Telescoping arm Jeff 801 Technical Discussion 12 06-15-2007 02:41 PM
Telescoping Arm ArmoredFairy698 Technical Discussion 17 06-14-2005 11:26 AM
Chain Driven Telescoping Arm BadKarma Technical Discussion 8 06-05-2005 12:19 PM
pic: Team 930 telescoping arm CD47-Bot Robot Showcase 1 02-13-2004 04:24 PM
telescoping arm CharlieWilken Technical Discussion 45 01-26-2004 10:22 PM
