Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 08-02-2010, 18:05
Steve G.'s Avatar
Steve G. Steve G. is offline
FRC #2549 (Millerbots)
Team Role: Student
Steve G. is an unknown quantity at this point
Send a message via AIM to Steve G. Send a message via Yahoo to Steve G.
Question Re: pic: 1747- Kicker Winch
What is the length of your pneumatic cylinder? What is the bore measurement?
Unread 08-02-2010, 18:14
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
Be careful of calculating the frictional forces on the gear you are pulling.
Are you pulling a dog gear ??
We are using a similar system but using 2 pneumatics ... the dog gear winds the capstan and the tension is held by a ratchet and pawl... we then pull the dog gear with a pneumatic and release the kick with the 2nd pneumatic which releases the pawl.
Our design engineer thought that the friction in the dog gear would be too great to pull effectively with a short throw pneumatic.
good luck..
cool design..
We are winding with a Banebot transmission and a FP motor.
Unread 08-02-2010, 21:55
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
No, we are just disengaging a 50-tooth gear. We used parts from an old AM Gen 2 and an off-the-shelf ratchet to test the dog gear-ratchet approach, but like you said, the friction forces prevented the dog gear from disengaging. After trying a number of things (like beveling down the "teeth" of the dog gear), we switched to this idea.
It is a 1.5" bore cylinder with a 1/2" throw.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 09-02-2010, 22:57
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
It's been a little while since I've seen a mesh-shifter in FIRST, and this is about as close as I've seen recently. Definitely cool, used to be a lot more stuff like this in FRC.
pic: Winch for Kicker MrForbes Extra Discussion 10 10-02-2010 10:42
pic: 1747 Teaser 1747robotics Extra Discussion 3 07-02-2010 23:57
pic: Buckeye: 1747 Panda Pose Dan 1038 Extra Discussion 9 03-03-2009 17:23
pic: 1747 Turret Close up Allison Robot Showcase 2 20-02-2007 10:16
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
