Go to Post Keep in mind that the lady Amanda has just taken a new job, moved herself to the NorthEast, and has to put up with people like Grady, Needel, the Kelsos, and Boucher. Let's give her some patience and sympathy. - Andy Baker [more]
Unread 10-02-2010, 17:54
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: 1640's 2010 Pivot Assembly
The wheel is a 4" Andymark Plactraction and the chain is #35. The wheel dead axial is a stud with nuts on both sides of the plates which provides more stiffness to the cage. We put ball thrust bearings on the bevel gear shafts to control the thrust forces. There are roller needle bearings for the vertical bevel shaft. The entire unit rotates on a combination of thrust bearings and ball bearings. For the pivot purists, having 4 steering motors allows proper wheel angle setting when turning. For chassis rotation the correct angle and velocity for the inner wheels is different than the outer wheels. We choose the window motors because they are the only way to get 4 matched motors and we wanted the FP motors for the ball processors. The kicker is pneumatic. Getting the gears and angle sensors set up on the window motors took some effort. We are using Cherry Electrical AN8 sensors and they seam to work well. The actual area on the robot taken up by the pivot assembles , steering motors and cims is relatively small. As some teams have found out the window motors are a little weak to drive 2 pivot assembles. We are driving ours 1 : 1. The programmers are having a tough go but on Tues. things were going better. This is our first try at this and it has been allot of work. Hopefully the agility will make the pivot drive worth it. And yes it drives very well over the hump.
Learn PIC assembly bronxbomber92 Programming 13 06-01-2008 12:23
pic: Team 1640's '05 Bot coastertux Robot Showcase 10 25-02-2005 12:40
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
