Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 13-02-2010, 21:21
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: pic: 48 Kicker Winch
Darn, the first dry run didn't quite work. We are having issues with a set screw holding the drive gear on the shaft. As the gear rotates under load the set screw is digging into the inside wall of the spool. I am thinking of taking another note from AM on this one and using a star retainer over the shaft instead of the set screw.
We haven't set up the pneumatics yet to see if the pressure on the cylinder will pull the dog but using a screw driver to do the job we found the friction on the clutch to be quite extreme.
Tomorrow will hold our answers.
--A. Reed
~The Designer~
pic: Winch for Kicker MrForbes Extra Discussion 10 10-02-2010 10:42
pic: 1747- Kicker Winch 1747robotics Extra Discussion 14 09-02-2010 22:57
pic: 2010 window motor winch Iceman1330 Extra Discussion 18 17-01-2010 14:50
pic: Vex Winch AdamHeard Extra Discussion 5 16-11-2006 23:30
pic: team 60 winch CD47-Bot Robot Showcase 3 01-03-2004 10:36
