Re: pic: 1024 Chassis with Biohazard Wheel
I think the side is like a half roll cage, so if they tip forward, you can push under it and gain leverage to right them?
Or, much more likely, "just" a hanging arm. |
Turning is overrated |
Bouncing balls back towards your zone off
the tower? That'd be my best guess. |
pretty sure the GDC made that illegal
That rule only limits the intrusion of the ball to 3" inside a mechanism above the bumper zone.
A ramp has 0" of intrusion. You could also have a funnel of some sort with 3" tall sidewalls, that would be 3" of intrusion. |
id have to disagree, id have to say that there is like walls around your robot at 3" and if at any point a ball comes in contact with your robot within those walls, then that should be the 3" rule penalty
#11
ok, so then let me see if i am understanding you guys correctly, the 3" rule only applys to the mechanisms or the robot?
#13
Below the Bumper Zone the ball may only intrude 3" inside the Frame Perimeter as detailed in <R19-A>. |
#14
How about some details on those wheels? Are those the upgraded sheet wheels you guys were showing off in 2008?
#15
are you guys planning to have kickers on all sides or is that for ground clearance
| pic: 4 Wheel Strafing Chassis | Holtzman | Extra Discussion | 9 | 08-07-2009 19:28 |
| pic: 1024 Kilabytes Painted Chassis and Hopper | Michael Long | Extra Discussion | 12 | 18-02-2009 22:05 |
| pic: Universal Chassis with Toughbox Adapters | ajlapp | Extra Discussion | 1 | 28-12-2008 23:19 |
| pic: FRC488 - Six Wheel Drive Chassis | Madison | Technical Discussion | 38 | 23-01-2007 10:58 |
| MXR 1120 Chassis & Wheel Hub | MXR1120 | Robot Showcase | 4 | 26-01-2005 00:33 |
