Go to Post but you can rest assured: I have restored the balance by letting the GDC know that I know that they know that you know they have a pattern. -Leav - Leav [more]
Unread 14-02-2010, 11:37
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: pic: 1024 Chassis with Biohazard Wheel
Originally Posted by dodar View Post
pretty sure the GDC made that illegal
Rule or Q&A link?
Unread 14-02-2010, 11:40
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
http://usfirst.org/uploadedFiles/Rob...Update%202.pdf
R19
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 14-02-2010, 11:47
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
That rule only limits the intrusion of the ball to 3" inside a mechanism above the bumper zone.
A ramp has 0" of intrusion. You could also have a funnel of some sort with 3" tall sidewalls, that would be 3" of intrusion.
Unread 14-02-2010, 11:49
terryo terryo is offline
AKA: Terry O'Brien
FRC #1784 (Litchbots)
terryo is an unknown quantity at this point
I'm with Vikesrock on this one. As long as the ball bounces off without 'depressing' the deflecting mechanism/ramp 3", your golden.
Unread 14-02-2010, 11:53
dodar's Avatar
id have to disagree, id have to say that there is like walls around your robot at 3" and if at any point a ball comes in contact with your robot within those walls, then that should be the 3" rule penalty
Unread 14-02-2010, 11:57
DonRotolo's Avatar
Back to humble
FRC #0832
Here is <R19> in its entirety:
<R19> ROBOTS must be designed so that in normal operation BALLS cannot extend more than 3 inches inside
a) the FRAME PERIMETER below the level of the BUMPER ZONE (see Figure 8-5),
b) a MECHANISM or feature designed or used to deflect BALLS in a controlled manner that is above the level of the BUMPER ZONE.
Indeed, Vikesrock's interpretation is what I get as well.
Unread 14-02-2010, 12:03
dodar's Avatar
ok, so then let me see if i am understanding you guys correctly, the 3" rule only applys to the mechanisms or the robot?
Unread 14-02-2010, 13:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Above the Bumper Zone, yes, that is correct. That part is covered by <R19-B>.
Below the Bumper Zone the ball may only intrude 3" inside the Frame Perimeter as detailed in <R19-A>.
Unread 14-02-2010, 20:09
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How about some details on those wheels? Are those the upgraded sheet wheels you guys were showing off in 2008?
Mentor 2415
Unread 14-02-2010, 20:50
are you guys planning to have kickers on all sides or is that for ground clearance
Unread 14-02-2010, 21:06
Allison Allison is offline
AKA: Allison Phelps
FRC #1024 (Kil-A-Bytes)
Allison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant futureAllison has a brilliant future
I was wondered how long it would take someone to catch my title about the wheels.
Hopefully our students will be assembling some tomorrow and I can get a good picture of one. They are similar to the design that was created in 2008 but 8 inches and have a biohazard symbol as the lightening pattern.
Unread 14-02-2010, 22:32
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
It looks like the structure could be used to right the position of the robot if it flips over when going over the bump
Unread 15-02-2010, 15:12
AKA: Sean
Id love to see pictures when you get them assembled. Also are you planning on marketing the wheels anytime soon?
Mentor 2415
Unread 15-02-2010, 18:28
AKA: Allison Phelps
Here is one of our traction wheels. Right now we don't have any plans on marketing them but maybe in the future if the right opportunity arises.
http://www.chiefdelphi.com/media/photos/34843?
pic: 4 Wheel Strafing Chassis Holtzman Extra Discussion 9 08-07-2009 19:28
pic: 1024 Kilabytes Painted Chassis and Hopper Michael Long Extra Discussion 12 18-02-2009 22:05
pic: Universal Chassis with Toughbox Adapters ajlapp Extra Discussion 1 28-12-2008 23:19
pic: FRC488 - Six Wheel Drive Chassis Madison Technical Discussion 38 23-01-2007 10:58
MXR 1120 Chassis & Wheel Hub MXR1120 Robot Showcase 4 26-01-2005 00:33
