Re: pic: 1024 Chassis with Biohazard Wheel
That rule only limits the intrusion of the ball to 3" inside a mechanism above the bumper zone.
A ramp has 0" of intrusion. You could also have a funnel of some sort with 3" tall sidewalls, that would be 3" of intrusion. |
id have to disagree, id have to say that there is like walls around your robot at 3" and if at any point a ball comes in contact with your robot within those walls, then that should be the 3" rule penalty
ok, so then let me see if i am understanding you guys correctly, the 3" rule only applys to the mechanisms or the robot?
Below the Bumper Zone the ball may only intrude 3" inside the Frame Perimeter as detailed in <R19-A>. |
How about some details on those wheels? Are those the upgraded sheet wheels you guys were showing off in 2008?
are you guys planning to have kickers on all sides or is that for ground clearance
#10
Hopefully our students will be assembling some tomorrow and I can get a good picture of one. They are similar to the design that was created in 2008 but 8 inches and have a biohazard symbol as the lightening pattern. |
#11
It looks like the structure could be used to right the position of the robot if it flips over when going over the bump
#12
http://www.chiefdelphi.com/media/photos/34843? |
| pic: 4 Wheel Strafing Chassis | Holtzman | Extra Discussion | 9 | 08-07-2009 19:28 |
| pic: 1024 Kilabytes Painted Chassis and Hopper | Michael Long | Extra Discussion | 12 | 18-02-2009 22:05 |
| pic: Universal Chassis with Toughbox Adapters | ajlapp | Extra Discussion | 1 | 28-12-2008 23:19 |
| pic: FRC488 - Six Wheel Drive Chassis | Madison | Technical Discussion | 38 | 23-01-2007 10:58 |
| MXR 1120 Chassis & Wheel Hub | MXR1120 | Robot Showcase | 4 | 26-01-2005 00:33 |
