Re: pic: Team Overdrive's Mini Breakaway Field
Originally Posted by spiffyspleen
Ok, our team has an important question about the field shown here. So, you know the ball return ramps? Do those end as far back as is shown here, or do they end closer to midfield? We need to know if we need to retract our arm or not.
Thanks a lot.
Team 2635.
P.S. I have to agree that you should put hexbugs in there
Yes, we tried to build the field as close to regulation as possible, excluding size. In the real Breakaway field, the ball return ramp ends at about the end of the tower it is supported by. This means that the balls will land in the midzone while the return ramp doesn't actually extend into the midzone itself.
If you want to see this in real life size, check out the FRC game animation or the field at the FRC Kickoff.
Team Overdrive FTC #2753
A big thank you to all of our sponsors and supporters!!
2006/2007: FVC #3179 - New Jersey Champions
2007/2008: FTC #74 - Ohio, Delaware, New Jersey, New York, and World Champions
2009: FRC #2753 - New Jersey Champions &
Archimedes Division Champions  PARC champs, BRBR champs, & Brunswick Eruption champs
2010: FRC #2753 - NJ semifinalists, Philly semifinalists, ranked 44th in Archimedes division
2011: FTC #2753 - DE semi-finalists, NJ division finalists
