Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 17-02-2010, 22:34
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
pic: Team 935's Chassis
Unread 17-02-2010, 22:37
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
Re: pic: Team 935's Chassis
It's not gonna crumple if a robot falls on it right? Plus why the 80-20?
I do like the triangular and circular cutouts but it seems like too much was taken out.
Is there an arm?
How much does it weigh?
Very interesting.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 17-02-2010, 23:12
FlyingHedgeHog's Avatar
FlyingHedgeHog FlyingHedgeHog is offline
AKA: Jonathan
FlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud ofFlyingHedgeHog has much to be proud of
... How many CIMS is that? I think it might be over 5, and you're only allowed 5...
Unread 17-02-2010, 23:16
EricH EricH is online now
I only see 4 CIMs, all on the drivebase. I also see a window motor in the far back corner.
Unread 17-02-2010, 23:18
AKA: Jonathan
Oh, I see. Sorry, these hours must really be getting to me.
Unread 17-02-2010, 23:46
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
nice, a low mecanum robot that climbs, i wanted to do something like that but with non driven omni wheels, hope to see you compete
Unread 18-02-2010, 00:00
p8blr's Avatar
p8blr p8blr is offline
2009 Team Captain
FRC #0935 (RaileRobotics)
p8blr is an unknown quantity at this point
I wouldn't worry about that too much, it's been a robust concept since 2006.
http://team935.com/media.php?photos
gears go like that...
Unread 18-02-2010, 00:02
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Why did you CNC so much? I only ask because to me it would make more sense to build a separate upper frame instead of extending the CNC so high up.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 18-02-2010, 00:06
The last three posts of this thread pose similar questions and comments. Left unanswered to curious minds.
http://www.chiefdelphi.com/media/photos/34715
Is there an arm?
Very interesting.
Their triangular pattern is very strong. Even with pocketing, the pattern plus the fact that it is quarter-inch 6061 allows their frame to be very rigid and strong. It will not "crumple."
mjazzka's Avatar
mjazzka mjazzka is offline
THUNDERCAT
AKA: Michael Jaska
FRC #0624 (Cryptonite Robotics)
mjazzka is infamous around these parts
Hmm, VERY interesting. It appears to me that when your robot is flat on the ground (like it is now) the middle four, non-mecanum wheels, are off the ground? So that would mean that they are only for getting over the bump. At least, it LOOKS like the axis of the shafts are not the same (see below).
http://s950.photobucket.com/albums/a...a.jpg&newest=1
Other than that, I am curious to see how ya'll elevate/score, I can't tell from the photo...
Good luck this year!
-624
Coach/Strategist, and Manipulation Captain for 2009 "Lunacy"
Ultimate Frisbee Enthusiast
Unread 18-02-2010, 00:21
Brandon Holley's Avatar
To go along with some of the other comments here...
Where the bumper zone is on your robot appears to be the weakest area in terms of structure, at least from what I can tell from these pictures. We build our drivetrains (among other things) in a very similar manner as you guys. We use 1/4" aluminum plates, and use round standoffs to hold them together. This is what you have done in your drive system, but above the drive system there does not appear to be any standoffs. Seeing as this is where the bumpers will be, and thus most of your interaction with other robots will be, are you concerned about bending in that area?
Also, was that milled or waterjetted? If it was milled, I'd love to see some pictures of it in process if you have any.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 18-02-2010, 00:25
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I think that is a work of art.
Are you planning on using shims for attaching bumper? Your gonna have to do something to make those wheel bearings and screws legal.
Unread 18-02-2010, 00:38
J_Beth J_Beth is offline
AKA: Justin Beth
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
well, wouldn't it make more sense to make it out of one part instead of having multiple parts that could break, and have to be made with close enough tolerances to fit together.
"I Wanna Be A Robot Maker!!!!"
Unread 18-02-2010, 01:09
p8blr's Avatar
2009 Team Captain
It's not gonna crumple if a robot falls on it right?.
I wouldn't worry about that too much, it has proven to be a light, yet robust way of creating a custom chassis to the parts our bots require. Four years running with this design, and no structural failures yet.
Unread 18-02-2010, 17:48
mjazzka's Avatar
THUNDERCAT
AKA: Michael Jaska
In SOME things that is true, but a whole robot? If this frame got hit hard (which it will), there is a good chance that it would bend. You cant replace a bent part of a robot that is one giant piece. Unless you have infinite quantities of those plates! And besides, building the robot with good ol' nuts and bolts is fun!
pic: Team 223 Chassis jjjeski Extra Discussion 26 17-02-2010 23:53
Pic: Team 935's nearly complete chassis railerobotics Robot Showcase 44 20-02-2008 12:11
pic: Team 1058 chassis PVCMike Extra Discussion 3 30-01-2007 22:28
pic: Team 27 2004 Chassis CD47-Bot Robot Showcase 2 25-02-2004 23:29
pic: Team 369 Chassis CD47-Bot Robot Showcase 7 11-02-2004 19:58
