Go to Post If you think that teams would never bypass the rules or do something unsafe (intentional or unintentional), I suggest you spend a weekend as an inspector. Every bad scenario that you can think of, we have seen. - Al Skierkiewicz [more]
Unread 18-02-2010, 08:02
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
pic: Team 935's kicker teaser
Unread 18-02-2010, 08:05
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: pic: Team 935's kicker teaser
I think it's a similar design to what Winnovation came up with for Overdrive. I loved the idea, but didn't go for it because of the lack of adjustability in kicking didsance. There are ways to adjust these type kickers, but I didn't want to invest the weight in them.
Am I right?
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 18-02-2010, 10:30
FRC #0935
We have a spool that winds the surgical tubing to create tension on the kicker. That way we can adjust how far it kicks.
Inspiration of Today,
Technology of Tomorrow.
Team 935
http://www.team935.com
Unread 18-02-2010, 11:57
J_Beth J_Beth is offline
AKA: Justin Beth
FRC #0935 (RaileRobotics)
J_Beth will become famous soon enoughJ_Beth will become famous soon enough
Is that a Double Doozy that I see attached to that gear box?
"I Wanna Be A Robot Maker!!!!"
Unread 18-02-2010, 15:24
Josh Drake's Avatar
Engineering Mentor
Good idea. The pneumatic kickers will have the same problem if they see it as a problem. I wanted to make sure we could blast it if far away and pooch it if closer. Good luck.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
pic: Team 935's Chassis railerobotics Extra Discussion 18 20-02-2010 00:53
pic: Team 935 kicker teaser #1 railerobotics Extra Discussion 6 23-01-2010 12:15
FRC1577 Kicker Teaser NirZiv Robot Showcase 0 23-01-2010 06:01
FRC114 Kicker Teaser James114 Robot Showcase 10 22-01-2010 16:56
Pic: Team 935's nearly complete chassis railerobotics Robot Showcase 44 20-02-2008 12:11
