Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
Unread 18-02-2010, 12:42
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
Re: pic: Window sprocket adaptor
http://www.facebook.com/home.php?#!/...8&id=530290273
the motors hold the adapter from moving. We already have taken care of the motors at moving different speeds.
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 19-02-2010, 00:20
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
We would be interested to know if you have any trouble with your Denso motors overheating and cutting out. We had two Densos mated exactly this way for our swerve steering, but had to switch to steering with a CIM because the Densos would overheat and stop. Perhaps on a kicker they do not run enough to be problem. They are window motors so for safety they are designed to cut out when they stall on something and heat up. Not really the ideal motor to build robots with.
Unread 19-02-2010, 01:01
artdutra04's Avatar
VEX Robotics Engineer
We did, but that's because the theoretical load I calculated was between 1/2 and 1/3 of the observed necessary torque*. Using this figure, I found we were loading the Denso motors to 20 amps... and their stall current is about 24 amps. So using the observed torque, I back tracked and redid the gear ratio to maximize the power output and lower the current draw to a reasonable amount.
* I've pinned the reason for the discrepancy down to a few SWAGs at coefficients of friction between different materials not listed in the commonly available engineering tables like Machinery's Handbook. In the future I'll probably perform tests to experimentally ascertain these values instead of guestimating values at 2am...
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-02-2010, 07:18
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
We were having a similar problem last weekend. If you want, shoot me a PM with some pictures of your set up and I can try to offer some advice. We were able to make ours work with two windows powering four wheels (one on front set, one on back set). It sounds to me like you've got some friction somewhere in your system, just as we did.
Collin Fultz
CAD (Inventor) Wireless Adaptor? delsaner General Forum 3 02-02-2010 10:40
pic: Custom Machined Aluminum #25 Sprocket Holtzman Extra Discussion 24 10-10-2007 07:50
AC Adaptor? Jake M Electrical 28 12-06-2007 13:26
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
