Go to Post by the way when someone calles me a dork or geek, i tell them to look up dork and geek in the dictionary, and that i would rather be called nerd :) - Mike Schroeder [more]
Unread 19-02-2010, 02:22
Re: pic: Window sprocket adaptor
Originally Posted by =Martin=Taylor= View Post
You better make sure those motors are always turning at the same speed...
...otherwise its bye-bye Mr. Denso
If you power them with the same pwm value it's really not an issue based on the testing we've done. Been working fine all week for us.
I even took a pair driven together in my hands and tried to get them to rotate as differently as possible, they definitely handle a good deal of force difference while running together (at least at full speed).
Unread 19-02-2010, 07:18
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Originally Posted by jspatz1 View Post
We would be interested to know if you have any trouble with your Denso motors overheating and cutting out. We had two Densos mated exactly this way for our swerve steering, but had to switch to steering with a CIM because the Densos would overheat and stop. Perhaps on a kicker they do not run enough to be problem. They are window motors so for safety they are designed to cut out when they stall on something and heat up. Not really the ideal motor to build robots with.
We were having a similar problem last weekend. If you want, shoot me a PM with some pictures of your set up and I can try to offer some advice. We were able to make ours work with two windows powering four wheels (one on front set, one on back set). It sounds to me like you've got some friction somewhere in your system, just as we did.
Collin Fultz
CAD (Inventor) Wireless Adaptor? delsaner General Forum 3 02-02-2010 10:40
pic: Custom Machined Aluminum #25 Sprocket Holtzman Extra Discussion 24 10-10-2007 07:50
AC Adaptor? Jake M Electrical 28 12-06-2007 13:26
pic: Dual sprocket Dewalt drive Andy Brockway Extra Discussion 4 05-12-2006 08:05
pic: Sprocket mounting for window motor team222badbrad Extra Discussion 3 22-02-2005 03:06
