Go to Post sometimes you have to dig through the trash and clean off the layers of dirt and grime in order to find diamonds in the rough. - Travis Hoffman [more]
Unread 21-02-2010, 22:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Integrated, easy to use chain tensioners
Originally Posted by daltore View Post
We tried using a turnbuckle for this purpose on our arm motor in 2008, and every time we got any bit of tension on it, the loop side of the turnbuckle bent open. I hope it works for you, but do monitor the stresses on the turnbuckle hooks.
I would recommend using left and right threaded rod ends. They're able to sustain more misalignment and loading than the generic hardware store turnbuckles. One can order all of the parts from McMaster without much fuss.
pic: Modified/Integrated Transmission Thermal Extra Discussion 15 04-12-2009 12:47
pic: Sliding Wheel Chain Tensioners Ice Berg Extra Discussion 18 22-04-2009 00:45
pic: 2158 chain tensioners Richard McClellan Extra Discussion 9 14-02-2008 08:58
pic: Another Use for the Energy Chain! GRST Extra Discussion 1 19-01-2008 20:40
Chain Tensioners sanddrag Technical Discussion 24 25-02-2006 19:39
