Go to Post Do you mean...? If so, it's illegal under . (insert your favorite reminder to read the manual here) - EricH [more]
Unread 23-02-2010, 11:31
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: pic: Team 293's Robot
Originally Posted by Cyclotron View Post
The key to using 8020 is knowing how to join it without using joining plates, brackets or excess fasteners. This robot has only two joining plates, selected for convenience in servicing the drive train.
It looks like you're running a bolt through the outside plates and they are tapped into the piece they are connected to? Is this how you're eliminating the need for angle attachments?
How does this method hold up at competition? Do you put locktite or anything on the bolts? Do you have a problem with them staying tight?
Looks great. Good work.
Collin Fultz
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 469's Robot for 2006 pic 1 Don Wright Robot Showcase 11 24-02-2006 16:35
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
