Go to Post P.S. Who doesn't have CD as there homepage! (I mean, come on people. It's not like there's anything else to do on the net... :)) - Ryan M. [more]
Unread 23-02-2010, 15:21
Cyclotron Cyclotron is offline
Vice Chair, Mid-Atlantic Robotics
FRC #0293 (Team SPIKE)
Cyclotron is a jewel in the roughCyclotron is a jewel in the roughCyclotron is a jewel in the roughCyclotron is a jewel in the rough
Re: pic: Team 293's Robot
We counterbore clearance holes for 1/4-20 socket head cap screws (17/64 body, 25/64 head) and screw them into the tapped ends of the extrusion. McMaster sells a step drill bit to do this in one operation (drill press only!) Where 2 or 3 bolts would conflict at a corner, we use 8020 "end fasteners' which require only a #7 clearance hole for the hex key to tighten. Occasionally we use 8020 "anchor fasteners" which require a 9/16 counterbore in one extrusion.
We have done 45 degree and other angled connections. These require a careful drilling setup because of the profile shape.
These connections remain tight without locktite, but we always check everything just in case.
All of the fabrication steps for an 8020 frame can be learned by new team members very quickly, and the results are precise and as strong as they need to be. An 8020 frame is easier to put together than the Kitbot, and it is stronger, stiffer, and straighter.
pic: Team 469's Robot for 2006 pic 2 Don Wright Robot Showcase 10 26-02-2006 21:03
pic: Team 469's Robot for 2006 pic 1 Don Wright Robot Showcase 11 24-02-2006 16:35
pic: Team 1595 Final Robot Rookie TEAM L@@K!!!! sgsdragons Robot Showcase 4 01-03-2005 16:21
pic: Team 237 Robot and Team Scott Shaw 237 Robot Showcase 3 23-02-2005 19:54
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
