Go to Post TL, DR: You may be skilled at karate on your own, but imagine how much better you'll be with Mr. Miyagi mentoring you. - artdutra04 [more]
Unread 24-02-2010, 11:28
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: pic: Toltech modification of WildSwerve
Window motor and ANSI #25 chain for steering all four modules together. User controlled switch from single stick throttle for all-wheel drive or to a tank steer mode for zero degree spins left or right.
the entire modification was done to allow this drive-train to navigate the hump/bump. It has been tested in the shop but not on a practice field.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pic: Toltech '05 bot throws first pitch Andrew Schuetze Extra Discussion 5 29-04-2009 22:18
pic: Toltech Programming Protoboard Andrew Schuetze Extra Discussion 3 28-01-2008 13:44
paper: 07-08 Toltech recruitment flyers Andrew Schuetze Extra Discussion 4 18-09-2007 12:15
pic: Toltech Air Cannon Prototype Andrew Schuetze Extra Discussion 2 29-05-2007 15:29
pic: ULTIMATE - Toltech - Ponca City Picnic One Andrew Schuetze Extra Discussion 2 24-05-2006 10:44
