Go to Post And yes. The Super Bowl is on, and I'm replying to a thread on Chief Delphi... - BobbyVanNess [more]
Unread 25-02-2010, 18:53
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
pic: MORE Robotics 1714 Polycarb Wheels
Unread 25-02-2010, 18:58
CraigHickman
Re: pic: MORE Robotics 1714 Polycarb Wheels
Low center of gravity is good and all, but have you considered how the added weight will effect your acceleration with this year's tight quarters on the field?
Unread 25-02-2010, 19:59
wow...those things are nice... i wish that our wheels were that light
Unread 25-02-2010, 21:30
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Wait, you wish your wheels were 2lb a piece? What are you using? Mecanums? If so you're not too far off at 2.5lb a piece..
I mean, 2lb isn't exactly light for a wheel
Unread 25-02-2010, 21:54
well we are using 4 KOP AndyMarks, and 2 IFI's not too much more but those Lexan wheels look sick
Unread 26-02-2010, 08:46
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Is this a 3 piece wheel, or a single piece?
If it is a single piece, what are the lateral screws for.
Beautiful wheels guys.
Unread 26-02-2010, 12:12
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
The wheels are layers of polycarbonate. Solid one inch material is expensive. As far as the weight, 2 pounds is an estimate, so I will weigh one at the meeting tomorrow.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 26-02-2010, 15:40
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Ah, I see now. Looks like 5 layers right? 3 inner and two outer.
Unread 26-02-2010, 15:47
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Nice lookin wheels. Though if you wanted them to weigh as much as possible steel is a nice and dense material...
Unread 27-02-2010, 01:36
AKA: Joey
http://www.chiefdelphi.com/media/photos/34998
Just in case you have not seen any of our robots before, we try to build as clear as possible.
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 27-02-2010, 01:59
Maybe he wasn't clear on that.
Ok ok bad pun. But I couldn't resist.
Unread 27-02-2010, 07:45
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Clearly I had no idea and was using the sarcastic smilie for no reason
Hehe.
Unread 27-02-2010, 11:05
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
I have to agree with Craig, there are definite acceleration issues when you increase the weight of a wheel. This happens because the added weight resists motion and will fight you every time you try to change your direction of rotation or speed of rotation. This means slower to get up to speed, slower to stop, and more force on everything that powers the wheel including the chain and axles.
I like the creativity to get the center of gravity lower, but I really think you should bring alternative wheels if these give you too much troubles in competition.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 27-02-2010, 14:11
It wouldn't take that long to pocket these wheels if the weight became an issue, but knowing the guys on the drivetrain team this year, they probably took that into account when gearing, testing, etc.
Unread 27-02-2010, 15:05
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Mass isn't the issue. It's the Moment of Inertia (resistance to spin, which is a function of mass and radius) that could be the issue.
Per my rough calculations, the moment of inertia of an AM performance wheel and 1714's Lexan wheel differ by about 25%, and the actual ratio is slightly lower than this as the AM wheel has extra material near the axle that I didn't account for. I assumed an AM wheel is a rim and 3 sticks that span the inner diameter and the lexan wheel was a solid piece of Lexan.
Since you guys have the robot, have you noticed any adverse effects on performance? I'm still of the opinion that these wheels are super slick.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
pic: FRC 1714 More Robotics AJ R Extra Discussion 18 27-02-2010 16:11
MORE Robotics 1714 2010 Laaba 80 Robot Showcase 6 25-02-2010 00:19
pic: 1714 Polycarb prototype Crab Drive (backdrop1) xanarchyx Extra Discussion 38 01-11-2009 15:09
Thanks to MORE Robotics, team 1714 for Beta System demo Andy Baker Thanks and/or Congrats 4 20-11-2008 10:27
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
