Go to Post if we aren't here for some wisdom...what are we here for? - Molten [more]
Unread 02-03-2010, 18:21
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: pic: Team 980 Breakaway robot
Originally Posted by Ryan_Epperson View Post
That's what it seemed like to me. The chain on the Robot only brushes the carpet and in the 20+ times that they floored it over the bump the wheels were the only thing that ended up being damaged, the carpet was perfectly fine. So this would leave me to want to think that they are on then... but we need to check it out on thursday on the practice field to be sure
The way <R08> reads,
ROBOT wheels, tracks, and other parts intended to provide traction on the carpet may be purchased or fabricated (“traction devices” include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and the FIELD). In no case will traction devices that damage the carpet or other playing surfaces be permitted. Traction devices shall not have surface features such as metal, sandpaper, hard plastic studs, cleats, or other attachments. <snip>
I doubt inspectors will allow a chain that contacts the field. Chains close enough to the circumference of the wheel as to contact the field on a bump will provide (however small) propulsive and/or braking forces to the robot. Chains are made of metal, hence they are prohibited as traction devices. I would also worry about lubricant in the chain transferring to the carpet, thus violating <R36>.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 03-03-2010, 15:38
Ryan_Epperson Ryan_Epperson is offline
no team (WRRF)
Ryan_Epperson will become famous soon enough
Send a message via AIM to Ryan_Epperson Send a message via Yahoo to Ryan_Epperson
I agree. We are purchasing new gears as we speak and will be re-vamping the drive-terrain on thursday if it does in fact contact the carpet.
Unread 03-03-2010, 16:03
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
We too tried the belt drive system this year and it initially tested out pretty well, but when we added weight and really pushed it hard, the belts stripped out fairly quick (not all were properly tensioned). Do not even try to run belts without proper tension!!!
Work Hard, Have Fun, Make a Difference!
Unread 03-03-2010, 19:55
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
we're running belts this year with 2 cims and 1 fp per side and have not had any problems with them at all. We of course have them tensioned but other than that set up has been super easy and theyre much cleaner than chain.
Mentor 2415
pic: Team Paragon 571 2010 Final Breakaway Robot O'Sancheski Extra Discussion 7 07-03-2010 21:38
1986 Team Titanium Breakaway Robot jspatz1 Robot Showcase 12 28-02-2010 20:02
pic: Spam's 2010 Breakaway robot CaptainMcfuddel Extra Discussion 8 26-02-2010 21:40
Team 39 - 2010 Breakaway Robot! BornaE Robot Showcase 7 23-02-2010 23:25
pic: Team 980 Robot 2008 in LA ThunderChief Extra Discussion 3 13-04-2008 17:06
