Re: Leaking air
Without storage tanks, your 120psi volume is very small. With such a system even very small leaks will run you out of air fairly quickly. That being said, there is no reason why you shouldn't have a tight pneumatic system. Check everything that sees pressure. Not just the joints. The gages can leak, the relief valve can leak, the regulator can leak, the fittings can leak, the solenoids can leak. Systematically and throughly check one component at a time with soap bubbles, because you surely have a leak. While in the Navy, we had an apparent leak in one of our systems and it took me 7 months to track it down. Just because you haven't found it, doesn't mean it doesn't exist.
Re: Leaking air
Also, make sure the ends of the pneumatic tube were cut square. I've caught a couple leaks because someone cut the end at an angle and it could not go into the fitting far enough to make a good seal.
Re: Leaking air
Are you being generous enough with the teflon tape at the thread sealings? We taped the crap out of our pneumatic system, and combined with checking for flat cuts, our simple pneumatic system with a compressor, 1 air tank, and 2 solenoids with 3 pistons (kicker clutch and shifters) can hold the tank above 100psi overnight.
Re: Leaking air
No storage volume (tanks) is your primary problem. Without more volume, almost no system could hold full pressure for long even if well assembled. The smallest leak will cause pressure loss fairly quickly. If your robot can accomodate tanks, add them. They are a common component of a system for good reason.
Re: Leaking air
You wanna check your tubing first. I would recommend using smoke over water.
If it continues to leak, I recommend having some fun with duct tape, which is legal this year. ![]() |
Re: Leaking air
We usually don't bother with more than 2-3 wraps of teflon on my team or at my company for these reasons. If you properly tighten the fittings, this is more than enough to get a good seal, and little enough to not cause you problems. |
Re: Leaking air
Too much tape can also cause problems with fragments getting into the air flow and reaching the solenoid valve spools, where they can jam spools and cause a failure. A couple of wraps is sufficient. Just assemble your system tightly and with care.
Re: Leaking air
by "tape the crap out of it" I mean "tape the crap out of it until there is plenty but not too much". We don't have more than 3 wraps on any one fitting.
| FESTO Leaking Air | sbelding | Pneumatics | 2 | 20-02-2010 16:47 |
| Leaking Solenoid? | ygd | Pneumatics | 5 | 03-02-2010 00:31 |
| Microwave leaking? | sanddrag | Electrical | 8 | 30-08-2006 20:06 |
| Are we allowed to use a Bimba air-to-air booster? | Alex Minot | Pneumatics | 1 | 20-02-2005 22:32 |
| Leaking piston? | Bill Becker | Pneumatics | 6 | 23-03-2004 18:10 |
