Go to Post Wait hold the phone. Do you mean its physically possible to not spend time on robotics during the season?!!! Too much.......for brain......to compute!...goes against.....beliefs........aaaaarrrrrrghhhhhh!!! [syntax error] - BuddyB309 [more]
Unread 10-03-2010, 10:29
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: pic: Team RUSH 27 Hanging at Kettering
Our kicking mechanism is powered by surgical tubing similar to our '08 catapult. In fact, the idea for this kicker is nearly identical to that catapult.
We have spectra cable attached to our kicking arm which is then winched back to one of several positions determined by driver input and pot position by a fisher price (I believe it's the FP, not 100% sure).
Inside the gear box is a dog gear, which is actuated to allow the winch to free-spin, releasing the force from the stretched surgical tubing cartridges made using pneumatic hose clamps and connectors that are then attached by carabiners to the kicker and a stationary point on the back of the robot. We have four of these "cartridges," made up of one surgical tubing loop and a carabiner at each end. Each cartridge is rated to 50 lbs of force I believe.
The dog gear is actuated by a cam that's spun by a window motor.
We also power our lift with a CIM, and I'm not sure on the ratio. I'll try and find out to get back to you.
It will do the lift without surgical tubing, the tubing is just in place to give it a little extra help.
Team RUSH Alumnus (2007-2010) and Mentor (2014-Present)
Unread 10-03-2010, 10:59
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
27 was a super cool machine to watch play. This is especially true after they started using their lifter on Saturday.
Very strong machine that the team should be very proud of.
Unread 10-03-2010, 11:34
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
You should put sponsor stickers on the bottom of your bot. Or something else. Make it more fun!
Unread 10-03-2010, 11:41
AKA: Foxy
If you're interested in seeing more pictures of our robot we have about 500 that were taken by one of our mentors' dad.
http://s997.photobucket.com/albums/a...tering%202010/
Unread 10-03-2010, 11:51
drtysteve384 drtysteve384 is offline
AKA: Christian
FRC #0384 (Sparky 384)
drtysteve384 is on a distinguished road
that is $%#@ insane that is one of the most coolest lifters i have ever seen congrats on that succes, man that looks sexy..
384 Mentor
VCU Regional 2nd Place Finalist
pic: Killer Bees (Team 33) Hanging - Kettering District Finals Eric Yahrmatter Extra Discussion 1 09-03-2010 13:04
pic: Team RUSH 2008 ajlapp Robot Showcase 5 21-02-2008 18:24
pic: Team RUSH 2008 Jimmy Holmes Robot Showcase 4 20-02-2008 21:25
pic: Team RUSH 2007 ajlapp Robot Showcase 6 20-02-2007 18:28
pic: Team Rush 27 ajlapp Robot Showcase 5 22-02-2006 09:10
