Go to Post Perfection of a system comes not when you can add nothing more but instead when you can remove nothing. - Andrew Schreiber [more]
Unread 14-03-2010, 22:54
Jno
FRC #0610 (Crescent Robotics)
Re: pic: 1114 hanging around
Originally Posted by Josh Fox View Post
What kind of wheels are they using?
And would anyone on 1114/anyone in the know care to explain how their lift works?
Very impressive, without a doubt.
Pneumatic wheels, not sure what kind.
I got a pretty good look at their hanging mechanism at Pittsburgh, works with the front arm that latches on to the bar with some high traction rubber on the bottom of it to grip onto the bar. They pull them selves up using a winch system that uses their 4 drive CIMs, it engages using a dog gear. Its really fast, they can get all the way up in less then 3 seconds. The top tail grabs onto the bar at the end of their climb to hold themselves up.
Co-Founder of Taplytics.com
pic: 1825 & 1806 hanging around at KC Martino Extra Discussion 1 07-03-2010 01:37
pic: 1114 and 48 hanging around in Canada Travis Hoffman Extra Discussion 3 04-05-2007 10:19
pic: 4 Bots, just hanging around CD47-Bot Extra Discussion 15 16-11-2006 21:27
pic: 177 Hanging around the practice field CD47-Bot Robot Showcase 2 09-04-2004 23:34
pic: 230 and 173 hanging around CD47-Bot Extra Discussion 16 23-03-2004 22:36
