Go to Post if we aren't here for some wisdom...what are we here for? - Molten [more]
Unread 14-03-2010, 23:06
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: pic: 1114 hanging around
Originally Posted by Jonathan Norris View Post
I got a pretty good look at their hanging mechanism at Pittsburgh, works with the front arm that latches on to the bar with some high traction rubber on the bottom of it to grip onto the bar. They pull them selves up using a winch system that uses their 4 drive CIMs, it engages using a dog gear. Its really fast, they can get all the way up in less then 3 seconds. The top tail grabs onto the bar at the end of their climb to hold themselves up.
They use a pneumatic cylinder to deploy the gripper.
1114 was prone to slipping down the bar earlier in the competition (Friday practice, I believe), making the hang not count - the tail slamming into the bar at the end of the hang was identified as the culprit. Softening the blow of that impact helped, but it still slips a wee bit every so often - just not enough to invalidate the hang. Something tells me they'll find a way to get rid of that altogether soon enough.
pic: 1825 & 1806 hanging around at KC Martino Extra Discussion 1 07-03-2010 01:37
pic: 1114 and 48 hanging around in Canada Travis Hoffman Extra Discussion 3 04-05-2007 10:19
pic: 4 Bots, just hanging around CD47-Bot Extra Discussion 15 16-11-2006 21:27
pic: 177 Hanging around the practice field CD47-Bot Robot Showcase 2 09-04-2004 23:34
pic: 230 and 173 hanging around CD47-Bot Extra Discussion 16 23-03-2004 22:36
