Re: pic: 2791 At WPI
Nice!
The bump problem is probably due to the interesting things that happen with 8wd and the center of mass of the robot, and the angles at which the forces work when the bot is at a 45 degree angle. I suggest you draw a free body diagram of the robot in the position where it gets stuck, and figure out the tractive force on each pair of wheels, and compare it to what is needed to get over the bump. Might be that adding some weight at one end of the robot, down low, will fix the problem. |
| pic: 2791 Completed Drivetrain | Chris is me | Extra Discussion | 6 | 13-02-2010 14:15 |
| pic: 2791 Teaser 1 | Chris is me | Extra Discussion | 18 | 26-01-2010 16:20 |
| pic: 2791 Final robot | yodameister | Robot Showcase | 13 | 21-02-2009 23:45 |
| pic: What is 2791 up to? | yodameister | Extra Discussion | 10 | 02-02-2009 18:21 |
| pic: Rookie 2791 progress | yodameister | Extra Discussion | 10 | 27-01-2009 21:45 |
