Go to Post Thou shalt becometh pinned in eliminations. - JesseK [more]
Unread 18-03-2010, 00:23
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: pic: 2791's Brand New Arm
Originally Posted by James Tonthat View Post
Flanges and more material, not more thickness.
Flanges are where you'll get the most bang for your buck. Once it starts bending with no flange, there's not much keeping it from continuing to bend. With a flange there is more material that needs to fail before that bending can continue.
Mathematically, bending depends on the moment of inertia, all other things being held equal. The moment of inertia of a rectangular section varies linearly with the length of the edge of rectangle parallel to the direction of the moment, and with the *cube* of the length of the edge of the rectangle perpendicular to the moment. That probably doesn't make a lot of sense*, but it gives you a *huge* increase in strength for a small flange that runs along the edge of you aluminum arm.
*Because I can't explain it well, not because it isn't true.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
pic: 2791's Shifting Winch Chris is me Extra Discussion 7 10-03-2010 07:46
Brand New Team TheKing General Forum 32 22-01-2008 09:02
pic: brand new custom built control center eshteyn Extra Discussion 35 14-01-2007 22:49
pic:THREE PICS OF NEW ARM!!!! LOOK!!!!!! sgsdragons Robot Showcase 0 13-02-2005 22:37
RAMBOTS, brand new webpage. archiver 2000 0 23-06-2002 23:06
