Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 19-03-2010, 22:14
jmanela's Avatar
jmanela jmanela is offline
+1 is BIGGER than -1
AKA: Joshua Manela
FRC #2586 (Fondy Fire)
jmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to beholdjmanela is a splendid one to behold
pic: Soccor balls stuck on ball return
Unread 19-03-2010, 22:16
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Re: pic: Soccor balls stuck on ball return
It turned out (from what I saw) that a ball was ripped, and so got caught in the ball return. Our human player tried pushing the balls as fast as he could down the chute, but nothing worked.
We ended out replaying the match.
And of course hanging again (as you can see )
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Are they stuck because the hanging 'bot has distorted the tower's geometry?
Unread 19-03-2010, 22:22
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Isn't this covered by <G18>?
FRC #0201 (FEDS)
No, they were stuck long before we hung. It was because one of the robots tore off a piece of the ball and it got snagged in the chute.
As noted above, they were damaged pre-ball return
'08, '09, '10
Unread 19-03-2010, 22:44
Wildcat's Avatar
Wildcat Wildcat is offline
AKA: Jeff
Team Role: Scout
Wildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the roughWildcat is a jewel in the rough
really? i heard on the webcast that it was cause some teams had some duct tape type of substance on their robot that rubbed off on the ball causing them to get stuck. oh btw good thing there was a replay, i was afk for the original XD
Network switch: $25
Gas, drinks, and pizza for a road trip to Troy:$50
Mountain Dew, Nachos, and Pizza at States:$200
Being a member of the Scouting Team: Priceless
2010 & 2011 Scouting Coordinator
2010 Back-up Driver (2-5)
Unread 19-03-2010, 22:50
FRC #0201 (FEDS)
Well that may have also been a cause, but I saw a triangular piece of the ball casing raised away from the ball when the match ended. The ref held it up, and that's what I saw. It may have been duct tape though. I was 30 ft away taking pictures.
And the first match was more exciting (7-4 instead of 5-1)
'08, '09, '10
Unread 19-03-2010, 23:07
The Cyborg's Avatar
The Cyborg The Cyborg is offline
That Awkward One
AKA: Mary Soltis
FRC #0051 (Wings of Fire)
The Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant futureThe Cyborg has a brilliant future
It's amazing how just a little bit of tape or ripped ball can cause a jam like that, especially when a couple of more balls fail to unjam it. Is this the only case of something like this happening?
Unread 20-03-2010, 07:17
GaryVoshol's Avatar
Cogito ergo arbitro
There were two cases of this at Cass.
One was user-induced when a robot's hanger mechanism stopped a ball from coming off the return (and generated penalties).
The other was caused when a faster-moving ball caught up with a slower one on the return, and the friction between the two ball surfaces caused them to slow down even further. The first ball dropped into the gap between the end of the return and the tower crossbar. <G18> was applied.
(since 2004)
Unread 20-03-2010, 09:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Someone should lash some 2006 pokey pokey sticks together and create the most entertaining volunteer position we've had since....the 2006 pokey pokey guy.
Unread 20-03-2010, 22:05
The Cyborg's Avatar
That Awkward One
AKA: Mary Soltis
Well, I found out today what the case was.
Apparently one of the teams had some sticky stuff on their gripper/kicker mechanism that managed to adhere to the ball, which caused the ball to slow down on the way down the ramp and get stuck in the space in between the ramp and the hanging pole on the tower (since the ball didn't have enough velocity to just simply bounce down). GooGone did the trick of getting rid of the sticky stuff on the ball .
Unread 20-03-2010, 22:24
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
This is correct.. I was working on the field and many teams were using duck tape on the front of there robots. We ended up rotating out 8 balls off the field, to help prevent this. Also, every team, that had something close to a sticky substance, was checked out to see if it was going to become an issue.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 20-03-2010, 23:14
The Cyborg's Avatar
That Awkward One
AKA: Mary Soltis
I also think that the gaffing tape used to line the field might be leaving some residue on the balls, so this issue can't be completely avoidable. It's all a matter of checking for anything obstructive on the balls before the match. I encourage every team and volunteer to double check for things like this before the match, and notify someone before any problems arise. Otherwise we will need to gather up some 2006 pokey pokey sticks as Travis Hoffman mentioned earlier
Unread 21-03-2010, 17:12
DonRotolo's Avatar
Back to humble
FRC #0832
Gee, that seems like a kinda hokey solution.
That's what it's all about.
Ball Return Worries indubitably Rules/Strategy 12 07-03-2010 16:02
Ball Return Time GKrummel Rules/Strategy 1 16-01-2010 14:26
Ball Return frank.pendzich Rules/Strategy 11 11-01-2010 09:19
Balls getting stuck in hopper FTtyler General Forum 30 09-02-2006 20:57
Low Priced soccor balls mnkysp6353 General Forum 0 08-01-2002 20:58
