Re: pic: 343, up without a doubt
Can you explain how the hanger works? I love the looks of it.
and im going to descibe how we are driving it now instead of in this picture.first, the entire mechanism folds down into the robot. it is held by a latch that runs off the motor's shaft. so, when the motor starts, the latch is released, which then releases the gas shocks. second, run into the pole. there are two spring loaded clips that clamp itself to the pole. third, a pneumatic is used to set the weight of the robot to begin to climb. fourth, two fisher price motors lift the robot up. and the wheel is a trailer boat roller. the only thing different are the motors, everything else will remain the same |
And the spring-loaded latching onto the pole step is very smart. Saves a whole lot of time lining up! I'm a little confused on Step Three, though. How do you "set the weight of the robot" with a pneumatic? ![]() |
The current lifter used in Florida is a GEM500 with 3 stages and a CIM. The new set up will be a double doozy, and two stages of the GEM500. Things will work on paper, but the true test will be tomorrow. Not quite double, but faster.
The setting of the weight thing with the pneumatics.... The spring loaded clips drive in and attach to the pole. Then the entire lifter mechanism pivots up via a cylender to force the rubber roller into the pole. Then turn on the motors and sit back. The silver flames are actually a decal like 342 uses. We were thinking paint at one point. This was one of Ziggy's senior projects, and it has turned out to be a success. Last edited by Josh Drake : 03-24-2010 at 07:47 AM. |
thank you josh
yeah, a little less than double speed because of different gearing. |
Ah, that makes sense. The output torque is lower because you're gearing the new motor assembly less. Did you need the 5th CIM elsewhere? Why not just remove a stage from the 3 stage GEM500 for more speed?
The youtube video Ziggy put up shows the robot pausing a couple times as it climbs. That's us tripping the 30A breaker, and waiting for it to reset. First thing at USF was to switch to a 40A. There is some concern that taking out a stage will trip the 40A. The two Fishers will allow us two 40A to make sure there isn't a problem. The removal of a stage may still be the way we go, but we're keeping some options open.
Loved your guys' bot, and watching you hang was a treat. 343 builds quality robots year after year.
One thing though, the event was held at Last edited by Barry Bonzack : 03-25-2010 at 12:38 AM. |
The double doosey didn't do it for us in Palmetto. The Fisher Price motors stalled and tripped the two 40A breakers. We did see where we were slipping going up the pole and fixed that. We were then able to climb with time to spare. It's still a work in progress that may have some minor tweeks before Atlanta. ![]() |
#10
i really like team 343, they've been amazing, i give double props to thier hanger it amazing, nice..
| pic: 343 at scrimmage | Josh Drake | Extra Discussion | 10 | 04-10-2010 01:40 AM |
| pic: 343 Teaser #1 | cziggy343 | Extra Discussion | 14 | 01-28-2010 10:09 AM |
| pic: 343 teaser #2 | cziggy343 | Extra Discussion | 5 | 02-08-2009 08:37 PM |
| pic: 343 robot | cziggy343 | Extra Discussion | 11 | 02-18-2008 03:40 PM |
| pic: 343 teaser | cziggy343 | Extra Discussion | 3 | 01-29-2008 07:22 PM |
