Go to Post It goes to show how a FIRST team is not one person but a complex codependence of people who are all striving to meet the same goal. - Bill_Hancoc [more]
Unread 03-24-2010, 12:34 AM
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Re: pic: 343, up without a doubt
Originally Posted by cziggy343 View Post
I would love to! and im going to descibe how we are driving it now instead of in this picture.
first, the entire mechanism folds down into the robot. it is held by a latch that runs off the motor's shaft. so, when the motor starts, the latch is released, which then releases the gas shocks.
second, run into the pole. there are two spring loaded clips that clamp itself to the pole.
third, a pneumatic is used to set the weight of the robot to begin to climb.
fourth, two fisher price motors lift the robot up. and the wheel is a trailer boat roller.
the only thing different are the motors, everything else will remain the same
So the same motor/motor group that provides the lifting force releases the latch (i.e. deploys the lifter)? That's clever!
And the spring-loaded latching onto the pole step is very smart. Saves a whole lot of time lining up!
I'm a little confused on Step Three, though. How do you "set the weight of the robot" with a pneumatic?
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 03-24-2010, 07:44 AM
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
The current lifter used in Florida is a GEM500 with 3 stages and a CIM. The new set up will be a double doozy, and two stages of the GEM500. Things will work on paper, but the true test will be tomorrow. Not quite double, but faster.
The setting of the weight thing with the pneumatics....
The spring loaded clips drive in and attach to the pole. Then the entire lifter mechanism pivots up via a cylender to force the rubber roller into the pole. Then turn on the motors and sit back.
The silver flames are actually a decal like 342 uses. We were thinking paint at one point.
This was one of Ziggy's senior projects, and it has turned out to be a success.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 03-24-2010, 11:07 AM
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
thank you josh
yeah, a little less than double speed because of different gearing.
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
Unread 03-24-2010, 11:12 AM
Ah, that makes sense. The output torque is lower because you're gearing the new motor assembly less. Did you need the 5th CIM elsewhere? Why not just remove a stage from the 3 stage GEM500 for more speed?
Unread 03-24-2010, 12:34 PM
Josh Drake's Avatar
Engineering Mentor
The youtube video Ziggy put up shows the robot pausing a couple times as it climbs. That's us tripping the 30A breaker, and waiting for it to reset. First thing at USF was to switch to a 40A. There is some concern that taking out a stage will trip the 40A. The two Fishers will allow us two 40A to make sure there isn't a problem. The removal of a stage may still be the way we go, but we're keeping some options open.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 03-25-2010, 12:35 AM
Barry Bonzack's Avatar
Happy Birthday! Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
...First thing at USF was ...
Loved your guys' bot, and watching you hang was a treat. 343 builds quality robots year after year.
One thing though, the event was held at
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
Unread 03-29-2010, 09:58 AM
Josh Drake's Avatar
Engineering Mentor
My bad. The thing about that typo is it represents a totally different school. UCF, Golden Knights, thanks for hosting.
The double doosey didn't do it for us in Palmetto. The Fisher Price motors stalled and tripped the two 40A breakers. We did see where we were slipping going up the pole and fixed that. We were then able to climb with time to spare. It's still a work in progress that may have some minor tweeks before Atlanta.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 03-25-2010, 11:58 AM
Mahekp15 Mahekp15 is offline
FRC #0442 (Redstone Robotics)
Mahekp15 is an unknown quantity at this point
i really like team 343, they've been amazing, i give double props to thier hanger it amazing, nice..
pic: 343 at scrimmage Josh Drake Extra Discussion 10 04-10-2010 01:40 AM
pic: 343 Teaser #1 cziggy343 Extra Discussion 14 01-28-2010 10:09 AM
pic: 343 teaser #2 cziggy343 Extra Discussion 5 02-08-2009 08:37 PM
pic: 343 robot cziggy343 Extra Discussion 11 02-18-2008 03:40 PM
pic: 343 teaser cziggy343 Extra Discussion 3 01-29-2008 07:22 PM
