Go to Post Tragedies happened. We've learned from them, as individuals, as teams, as a community. - Taylor [more]
Unread 28-03-2010, 20:45
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Leaking Batterys
Originally Posted by MWB View Post
the battery came off of the charger at around 13v we tested it.
Unless it sat for a few hours first, or you put a small load on it for a few minutes before you tested it, you were measuring the battery's "surface charge". That tells you almost nothing about the actual state of health of the battery. A badly sulfated plate, or even a broken one that only has a small fraction of its bulk actually connected, can still be charged to full voltage. It just won't have anything like the capacity it should.
A stack of hearing aid batteries can also read 13v, but they won't run a robot.
Leaking air Yuan Xue Lim Pneumatics 10 09-03-2010 21:05
Leaking Solenoid? ygd Pneumatics 5 03-02-2010 00:31
Dule batterys Dark element Electrical 9 28-05-2009 18:49
Microwave leaking? sanddrag Electrical 8 30-08-2006 20:06
Leaking piston? Bill Becker Pneumatics 6 23-03-2004 18:10
