Go to Post For FIRST robots, the phenomena listed above just do not apply. - Paul Copioli [more]
Unread 03-30-2010, 01:21 PM
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
pic: 3280 Preparing to Hang (by tape measure)
Unread 03-30-2010, 01:23 PM
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Re: pic: 3280 Preparing to Hang (by tape measure)
I'm a bit curious as to how the hook gets up there in the first place, there don't appear to be any apparent mechanisms in the picture. Do you shoot it up somehow or have some kind of retracting hook arm?
Unread 03-30-2010, 01:37 PM
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Ooh! That is interesting.
How did you spool the tape measure up on the robot end? How was it attached to the drum? I'm sure the solid tape was in no danger of failing, but I'd be worried about pulling out at the holes if it were riveted to the drum. Then again, I've never done load testing on a tape measure, and really don't have a clue how strong the stuff is...
Were you worried at all about a failure from being hit while you were in the process of hanging?
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 03-30-2010, 01:47 PM
FRC #5279
The tape it stiff enough that it is used as an arm, we drive the tape from a spool at in the robot and it extends to the proper height. An IR line detector stops the tape at the correct height. The hook weighs ~2oz, so it is light enough to not cause the tape to fold.
We have the tape attached to a spool, driven by a CIM through a modified kit transmission (Additional stage added). To allow the tape to feed out we used recirculating bearings around the outside of the housing for the tape so when the tape uncoils and puts pressure on the out side of the case the bearings roll and guide the tape out of the housing. The tape's tensile strength is plenty strong enough to support the robot (we tested it up to 240 lbs with out failure). We reinforced the tape with aluminum at the hook and at the hub where we riveted it. If the tape is already damaged and the robot twists while hanging then breaking the tape is a concern. To avoid this we added two spring loaded bars in the front of the robot to allow it to ride up the poles (they are clearer in the other picture) and we inspected the tape after use. We designed the mechanism so it is easy to swap the tape if necessary, the whole process takes ~5min.
I have pictures of the mechanism on my phone, I will post them after work.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 03-30-2010, 02:33 PM
FRC #5279
Early testing video (poor quality) http://www.youtube.com/watch?v=jhdRaQZrORM Once the Boston regional videos are up I will link to a better video.
Close up of hanging mechanism http://www.chiefdelphi.com/media/img...5851ad94_l.jpg
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 03-30-2010, 02:40 PM
FRC #5279
Matches the blue alliance has posted that we hung in.
http://www.thebluealliance.net/tbatv/match/2010ma_qm37
http://www.thebluealliance.net/tbatv/match/2010ma_qm51
http://www.thebluealliance.net/tbatv/match/2010ma_qm57
http://www.thebluealliance.net/tbatv/match/2010ma_qm70
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
that wasa very interesting idea. we thought about using a tape measure as a retraction mechanism for our robot's hooking arm, (once detached from the hook of course.) then we ran out of time and it was up to Mother nature and her gravity.
"To create a world where science and technology are celebrated... Where young people dream of becoming science and technology heroes"-Dean Kamen
This should start each year by focusing on worldwide issues, and having a game that, in theory if not practice, will help fix or compromise a solution with those issues, to make a better, safer worldwide and FIRST community.
Unread 03-30-2010, 03:08 PM
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Hang on... I thought tape measures were illegal! (jk) Oh, yeah, this is not the 2002 competition*.
Seriously, this is a wonderful use of a simple mechanism. Kudos to team 3280!
Sincerely,
Andy B.
* - For those of you who were not around in 2003, there was a big controversy regarding tape measures as extension devices. Initially, they were deemed that tape measures were illegal, but that eventually changed during the competition season. I am sure that this tape measure mechanism will bring back wonderful memories for those folks who were involved in that discussion.
Unread 03-30-2010, 03:11 PM
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Originally Posted by Andy Baker View Post
Hang on... I thought tape measures were illegal! (jk) Oh, yeah, this is not the 2003 competition*.
Sincerely,
Andy B.
COUGH2002COUGH
Unread 03-30-2010, 03:12 PM
Team 3280 was a very impressive rookie in Boston. It is clear that we can expect great things from them in the future.
Unread 03-30-2010, 03:15 PM
EricH EricH is offline
Baker, you've been doing this competition too long. Next you'll be saying that the game with tubes was 1997*...
In all seriousness, that's an interesting way to use a tape measure, as well as an ingenious way to avoid getting stuck in the tunnel while lifting.
*It was, by the way. It was also 2007.
Unread 03-30-2010, 03:53 PM
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
The tape measure lifter was definitely a crowd pleaser at Boston! Your team seemed to have executed it perfectly as well.
We would get that sense of anticipation whenever your team would take to the field with your tape measure hats. We had some guests sitting with us and it was fun to lean over and say, "just wait till the last 20 seconds!" And then after the lift was successful to tell them that you were a rookie team!
Great concept and congrats on your Rookie All Star award! I hope we will get to see you in Atlanta!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 03-30-2010, 11:14 PM
larrysz92's Avatar
larrysz92 larrysz92 is offline
Theory6 for the WIN!
FRC #1241 (Theory 6)
larrysz92 is an unknown quantity at this point
Send a message via MSN to larrysz92
wow very odd but unique! does it work? never seen that before! but anyways good job!
Tape measure anyone? Adam.garcia Technical Discussion 13 02-06-2010 02:14 PM
The First Tape Measure Olympics mlah Chit-Chat 15 04-14-2009 10:03 PM
pic: preparing for IRI. Arefin Bari Chit-Chat 17 05-25-2006 08:47 PM
Where's the Tape Measure? Jeff_Rice Chit-Chat 24 02-16-2003 12:49 AM
Tape measure proboscus tito General Forum 24 04-29-2002 03:56 PM
