Go to Post After all, if matches were determined by the numbers, we wouldn't need to have competitions. - jamierose [more]
Unread 22-04-2010, 17:57
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: pic: 1671 swerve module 2.0
Wow a lot of questions to answer.
Okay this is actually about 3 days old now.
and I fixed a lot of the concerns after doing a little more research on swerves as well as watching the robonauts conference.
Now the clips are gone. And replaced with bolts on the ends using a lathe on the shaft.
Also thrust bearings were modified to fit with the base.
The wheel is connecfted with the belt sprocket so the bottom axel is dead.
I will post the new one now that the version 2.0 is up.
I will also show how it connects with the base.
Thanks I really appreciate you guys helping me out with this.
Good enough is the enemy of anything great!
team 1671
pic: 1671 Swerve Module steelerborn Extra Discussion 14 20-04-2010 08:49
pic: Swerve Module Concept (View 1) Dave McLaughlin Extra Discussion 15 16-06-2009 22:36
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
