#17
Re: pic: 1671 swerve module 3.0
Here is the link to the bearings we are using.
http://www.silverthin.com/11jsa.htm?part=JSA020 The part number is JSA020. Thrust bearings are used against an axial force, meaning that the force is coming parallel to the shaft. So for instance with a swerve module the most likely force is going to come from a side hit, which is parallel to the shaft. Thrust bearings increase the strength of the module with the frame so that you can keep driving. |
| pic: 1671 swerve module 2.0 | steelerborn | Extra Discussion | 10 | 22-04-2010 18:41 |
| pic: 1671 Swerve Module | steelerborn | Extra Discussion | 14 | 20-04-2010 08:49 |
| pic: stangs swerve module | Aren_Hill | Extra Discussion | 8 | 23-04-2007 08:15 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
