Go to Post Dedicated students inspire parents and mentors, dedicated mentors inspire students. - Akash Rastogi [more]
Unread 27-04-2010, 17:54
CraigHickman
Re: pic: Sheet Metal Drivetrain
Are there any flanges on those cross members or spacer plates in between the blue drivetrain plates? That can easily add a lot more rigidity.
This. If you're curios about how much strength proper sheet metal flanging and bending can have, make a simple square out of cardboard, and try to bend or twist it. Then take a sheet of the same cardboard, and "flange" the edges (you might need a bit of tape to get to stay...). Try the same amount of bending and twisting, and you'll notice a large amount of extra rigidity. Even more so if you can stay away from rectangles and stick to triangles.
Looks like a good start, but you might want to take it easy on the cheese holing until your design is structurally sound...
What do you do with a sheet metal laser cutting sponsor? mikelowry Robot Showcase 4 05-02-2010 22:40
Left and Right configurations with Sheet Metal AustinSchuh SolidWorks 5 26-01-2010 02:24
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
New Sheet Metal Pattern Query easydub Inventor 4 13-07-2006 13:55
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
