Go to Post I believe the only cure... is more cowbell? :D - The Megan 2207 [more]
Unread 27-04-2010, 18:43
Rion Atkinson's Avatar
The CAD Guy
Re: pic: Sheet Metal Drivetrain
Originally Posted by apalrd View Post
It appears you dropped the middle wheels. That's good. Then it will probably turn. If you don't drop the center wheels or use omnis on the corners, it won't turn. And that would suck.
Well that's the understatement of the century.
To further on the "not turning" subject though, I can give an example in which shows you that wheel placement and such matters on your turning. I was talking to team 1561, apparently their students had a laps of brain function and took the kit bot and put 4 (Yes that's right, 4) AndyMark Roughtop 8" Plaction wheels. They were shocked when it didn't turn. What was the reason?
When the wheels are that far apart, the inside wheels rotate slow than the outside wheels. <Blah blah blah> That's the whole reason that cars have differentials. Other wise the inside wheel would have to skip. Your wheels have a better chance on slipping when you have a lower coefficient of friction. Well... Roughtop have a coefficient of friction that is rather high. So it will not slip very easily. See the issue with this?
Simple rule of thumb, the closer together your primary driving wheels are, the better your turning. <-Only applies to high friction wheels.
EDIT: Okay, I have to admit; you did a GREAT job with the CAD. How long have you been doing this? IT looks like you are using Inventor though; such a pity.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
What do you do with a sheet metal laser cutting sponsor? mikelowry Robot Showcase 4 05-02-2010 22:40
Left and Right configurations with Sheet Metal AustinSchuh SolidWorks 5 26-01-2010 02:24
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
New Sheet Metal Pattern Query easydub Inventor 4 13-07-2006 13:55
[OCCRA]: Bending Sheet Metal troy_573 OCCRA Q&A 1 19-09-2005 22:27
