Go to Post Great CAD ** work! ** Cardboard Aided Design - philso [more]
Unread 30-04-2010, 10:20
NickE's Avatar
NickE NickE is offline
_
Re: pic: 4 inch Wheel Render
Originally Posted by gyaniv View Post
This looks awesome!!!
Have you considered drilling a center hole instead of the hex hole and putting this on one side of each wheel?
I am almost sure that it will save you a lot of money when making those wheels... it might weigh a bit more but it will still be cheaper...
If you have a hex broach and an arbor press, it will be much cheaper than $15/wheel to get the hexagonal hole.
A 1/2" hex broach is only like $200 on McMaster, so if you plan on making more than 13 hex broached parts, its probably worth it. (A 6wd live axle would require 16: 6 wheels, 10 sprockets.)
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
pic: 1083 Render CD47-Bot Robot Showcase 9 19-02-2004 19:00
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
