Go to Post I am a firm believer that there is no model that can be transplanted/copied from one team to another and have the same level of success. There just isn't a formula for it. The mindset you should have is: "I know I have made a positive impact on my community". - tim-tim [more]
Unread 30-04-2010, 13:10
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Re: pic: 4 inch Wheel Render
I will agree with Nick on both counts.
A recess for the tread is the only way to go, then you only need two rivets at each end if the tread, the groove takes all the side load on the tread.
And the hex broach is far superior to bolting the A/M flanges on your wheels.
mike d
See Ya
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
pic: 1083 Render CD47-Bot Robot Showcase 9 19-02-2004 19:00
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
