Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Unread 30-04-2010, 13:52
artdutra04's Avatar
VEX Robotics Engineer
Re: pic: 4 inch Wheel Render
Originally Posted by NickE View Post
If you have a hex broach and an arbor press, it will be much cheaper than $15/wheel to get the hexagonal hole.
A 1/2" hex broach is only like $200 on McMaster, so if you plan on making more than 13 hex broached parts, its probably worth it. (A 6wd live axle would require 16: 6 wheels, 10 sprockets.)
If you're tight on money and like working with your hands, you can make your own hex broach for 'soft' materials like plastic or aluminum. All you need is an old HSS end mill, a lathe, and a precision grinder. It'll work good enough for FRC-style applications.
Art Dutra IV
世上无难事,只怕有心人.
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
pic: 1083 Render CD47-Bot Robot Showcase 9 19-02-2004 19:00
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
