Go to Post It's a bird! It's a plane! It's SUPER-TUBE! - dlavery [more]
Unread 02-05-2010, 21:01
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Re: pic: Rastogi 8wd Iteration 1.2
Originally Posted by jamie_1930 View Post
I immediately questioned why the metal was bent out and all though I don't have his answer to it in my opinion it is better to bend out because when you bolt things to the top it allows easier access to the nuts than reaching your hand around to the inside.
If you've got PEM nuts inserted in the flanges to bolt things to the top, you never need to reach under the flange to hold a nut...
*hint - Akash, PEM nuts are good - hint*
Looks really good, though. Really imposing. Keep it up!
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
