Go to Post It means Dave Lavery isn't on the Game Design Committee this year. If he were, you probably would have found a banana instead. - Alan Anderson [more]
Unread 04-05-2010, 07:22
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Re: pic: Rastogi 8wd Iteration 1.2
Originally Posted by Don Rotolo View Post
Second, you might consider putting flanges on some of those inside cutouts. Yes, it ends up a little heavier, but because the outer flange is not continuous you will suffer from low rigidity (and low resistance to bending) at certain points; use flanges to compensate.
I'm sort of in the process of leanring about the techniques of sheetmetal fabrication so I don't really know, but right now this is a fairly straightforward part to make, especially if you have a laser cutter. What I don't know is will adding those inner flanges add significantly to the fabrication time? I would imagine if in fact more strength was needed it would be easier and more robust to just add more cross supports between the inner and outer plate.
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
