Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 04-05-2010, 11:40
Re: pic: Rastogi 8wd Iteration 1.2
Originally Posted by ThaineP View Post
I'm not an experienced sheet metal designer, but what CAD program is that in?
Thaine
Solidworks 09-10 thanks to our Solidworks sponsorship through Marie Planchard.
Originally Posted by JamesCH95 View Post
I would add in some triangulation in the x-y plane. Other than that I think it looks solid.
What material were you planning on making it out of?
Its .09" thick sheetmetal. I'm not totally positive what grade of aluminum most teams use in their construction so right now I just had it set to 6061 T6. Anyone want to answer that?
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
