Go to Post There's more to the game then winning. - Gabriel [more]
  #41   Spotlight this post!
Unread 04-05-2010, 17:35
Data Nerd
FRC #0079
Re: pic: Rastogi 8wd Iteration 1.2
The "miracle" of this construction process to me isn't in the actual fitness for an FRC robot, since it's good enough to work as well as other materials. The appeal of it to me is that fabrication with a cool sponsor is automated and fast, so you spend less time machining and assembling and more time designing and thinking.
... in theory.
You can do that with a good tubular design too. Take a look at 2337's chassis, it was all bolt together using inserts into the tubes. Took a bit of time to do but was pretty simple. For reference, it was a combination of 1/8" and 1/16" thicknesses. The majority of it was 1/16" but the transmissions were 1/8" just to be safe.
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
