Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
  #43   Spotlight this post!
Unread 04-05-2010, 17:54
roboticWanderor's Avatar
Spark The Ancient
FRC #0418 (Purple Haze)
Re: pic: Rastogi 8wd Iteration 1.2
good work! i would put some wider cross bracings between the two pods, bend your flanges inwards and fiddle with your cheese holes a little. your lacking in some of the major stress areas and triangle departments. concept has some serious potential though. also if you run your cross braces to the outer plate of the drive pods they do a lot more for you.
take a good hard look at the slideshow in this :http://www.youtube.com/watch?v=_hTyXQUgYLE at how thier chassis is put together, pm or IM me if you wants some help with this.
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
