Go to Post You earn what you work for. - Akash Rastogi [more]
  #43   Spotlight this post!
Unread 04-05-2010, 20:51
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: pic: Rastogi 8wd Iteration 1.2
Try to get rid of all those spacer plates between the side plates by incorporating them into the inner side plate by bending the flanges in from the inner side plate. Might also think of building a low profile drive base and bolting on a frame with the robotic mechanism built on the frame. Doing so you can reuse the drive base design and build out a frame with the other parts for the robot.
Consider a bent sheet metal tray instead of the cross braces to connect the two sides together. As shown all the forces will be at the corners of your robot. It will be hard to square up and maintain a rigid frame with the cross braces.
Take a look a some pictures of our 8 wheel drive sheet metal chassis.
http://www.spartanrobotics.org/galle...Season&bac k=
Roy
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
