Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 06-05-2010, 22:51
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Re: pic: 6 inch wheel design
Originally Posted by A_Reed View Post
1.3 lbs may seem a bit heavy, but with no realistic numbers to run through the ANSYS FEA I have designed it to be overly robust with a 'standard' .25x.25 square cross section for each spoke. Anyone want to help me out on getting some realistic benchmarks for moment loading, side loads and radial loads.
It may not be the most accurate method, but I just place a fixed constraint on the hole for the shaft and apply 300lbf to the rim.
pic: 4 inch Wheel Render Chris is me Extra Discussion 25 15-05-2010 18:43
pic: 4 Inch Wheel Design MWB Extra Discussion 43 06-05-2010 19:32
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
