Go to Post My wife got mad at me when I told her I wanted to name our daughter Lotus. "What you mean the software?" she squawked. "No I mean the flower." I said. geeks, I swear.... - Koko Ed [more]
Unread 07-05-2010, 19:00
DonRotolo's Avatar
Back to humble
FRC #0832
Re: pic: Prototype Drivetrain
Originally Posted by 548swimmer View Post
because with 2 cims powering 1 wheel, we will have unlimited power
...until the wheel slips, at least.
Because of the moment of inertia of a relatively heavy mass swinging around a central axis with little friction (those omnis) you will find such a design difficult to control - even with a wider wheelbase.
Commenting on the sheet metal: Cut the thickness by 30% and put a 1" flange (bent inwards for both) at the top & bottom. Saves weight, adds significant rigidity. Some of the flange can be lost or reduced by the omni wheels for clearance if necessary.
To keep the assembly from racking (parallelogram), consider very thin braces from outside corners, in an X pattern. Even 1/8" wire rope would be fine, since it is in tension.
Your hole pattern could be improved. The solid pieces should all meet at stress points, not tangentially to them. See the small round 'pin' in front, 1/4 way from the left side of the image.
Nice CAD work.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
