Go to Post *quick grab the epoxy we can rebuild him, make him stronger than before* - amos229 [more]
Unread 07-05-2010, 19:11
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Re: pic: Prototype Drivetrain
Originally Posted by Don Rotolo View Post
...until the wheel slips, at least.
Because of the moment of inertia of a relatively heavy mass swinging around a central axis with little friction (those omnis) you will find such a design difficult to control - even with a wider wheelbase.
Commenting on the sheet metal: Cut the thickness by 30% and put a 1" flange (bent inwards for both) at the top & bottom. Saves weight, adds significant rigidity. Some of the flange can be lost or reduced by the omni wheels for clearance if necessary.
To keep the assembly from racking (parallelogram), consider very thin braces from outside corners, in an X pattern. Even 1/8" wire rope would be fine, since it is in tension.
Your hole pattern could be improved. The solid pieces should all meet at stress points, not tangentially to them. See the small round 'pin' in front, 1/4 way from the left side of the image.
Nice CAD work.
I am expecting this to be hard to control, and thats why I pulled the wheels toward the center. I figured it'd be spinning out of control untill you got the hang of it, so I should just design it for experienced drivers (hence the fast turn speed).
As for the metal, putting such a large flange on both pieces will leave a 1/2 inch gap between the side plates (only 2.5 inch spacing). I thought about just downgauging and flanging one piece (outside), but wanted to leave it simple for the first prototype CAD.
Supports: We have always been fine without any angle braces since the tubes go through a square hole in the inside plate. Would just a simple angle bracket suffice?
Lightening
Does it really matter since the piece will never be under tension/compression in the direction that the lightening will help?
As far as the CAD goes, I enjoy it, so I've gotten really good with basically teaching myself.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
